2024-04-23 10:42 PM
I'm looking to add a serial EEPROM to a product, and have a somewhat odd situation. The device will loose power spontaneously and often (few times an hour).
My question is: What happens if the M24C01-R looses power during a write operation? I assume at least that byte will potentially be corrupted, but does it have any other effects? What about if I write a whole page? Will the whole page be erased before the writing starts ?
( Of course I'll add CRC checks on the data so I know if I can trust it or not )
2024-04-26 9:32 AM
Welcome @CptSlow, to the community!
AN2014, section 6.2, will answer your questions and give you some recommendations.
Hope that helps?
/Peter
2024-04-26 9:32 AM
Hope that helps?
/Peter
