2006-05-08 2:24 AM
2006-05-04 4:21 AM
I am working on a project where there is a pushbutton.
My question is : Is possible to use the can pin to produce the pushbutton interrrupt? because the other External interrupt(XTI)pin are used for other device. Or Do you know if an other pin of the STR712 will be use like an interrupt for my pushbutton. Since regards Ludovic
