2007-09-27 10:15 PM
How can I program option bytes with Segger Flasher ST7
2007-09-26 03:11 AM
Hello All,
I have a problem with Segger Flasher ST7 programmer.Flasher ST7 requires option bytes within .hex file.I'm using cosmic c compiler for software development and could not find how can I include option bytes in .hex file while compiling the c code. Can anybody help me. Thank you.2007-09-27 09:33 PM
2007-09-27 10:15 PM
Dear Luca,
Thank you for your interest. I wrote the problem to Segger support team and they told me that, ''You must connect a target device to Flasher ST7 and then read the option bytes from the target and then edit the option bytes in dupm mode as you need and then save the file and merge the file with your source file.'' I think this method is unusual, but it works. Best Regards. Guray
