2003-10-23 11:07 PM
2003-10-21 9:44 PM
I work on st10f168, and i want to connect external RAM to it using EBC But in 8 bits MUX mode, i don't know which port is use to datas and adress. So if you use it in the same configuration, give me a answer THANKS a lot bye2003-10-23 11:07 PM
The data are on port P0L and the addresses on P0, P1 and eventually P4. for more detail have a look at the ST10x167 user's manual.
(ST10R167 and ST10F168 are fully compatible except for the program memory)
