Date code of M41T62LC6F
tkuo
Hi, how to read the date code marking on M41T62LC6F.
Example attached: 231C4
Thanks,
Peter BENSCH
@tkuo The RTC M41T62LC6F has been set to NRND (not recommended for new designs) and will soon be obsoleted. However, the characters in the second line, 231C4 in your case, can be interpreted as follows:
  • 2 = last digit of the year of manufacture (as the RTC was launched in 2003, your "2" can therefore stand for 2012 or 2022)
  • 31 = calendar week of the year of manufacture
  • C4 = lot number (internal)
Hope that helps?
/Peter
6 REPLIES 6
Issamos
Lead II
Hello @tkuo
This code is personal to ST products. I think it means lot C4 of 2012 or 2022 week 31.
Best regards.
II
Peter BENSCH
Hope that helps?
/Peter
Hello @Peter BENSCH
thank you for correcting my answer.
Best regards.
II
Thank you Peter.
I also had a question about the last digit of the year. How can I identify it is 2012 or 2022? Can the bulk ID on the label tell?
@davidousz See your other question.
