2004-09-02 8:53 PM
comunication with Master & Slave on ST7 and ST6
2004-06-13 4:04 AM
Hi; on any helps
I search an assembler or ST-Realizer2 application for a ST6265 master and a ST72331N4 as a slave, I have load same sample (without) an emulator, but there is no signal. Have any body thes realize in actual projekt. The world wait for these application. Best Regards[ This message was edited by: Goliath on 14-06-2004 00:34 ]2004-09-02 8:53 PM
Does your problem still exist? As a new member on this forum, it's a bit late perhaps but I'd like to point out that you perhaps did not initialize the Slave Select pin on the device. I know that Actum Solutions provides an application note and Realizer examples with their product. Check on www.actum.com. Balvie
