Atollic TS & CubeMX on Windows 10 - any knowing trouble?
i'm going to update my Win7-Professional to Win10; my question is :there is any knowing trouble to run Atollic TS or CubeMX on Windows 10?
Hi all,Attached my design with HVLED001 does not work. If i replece HVSU resistor with 1kOhm starts to works and output is ok but IC temperature getting very high quikly abouve 100C degree. IC supply voltage is okey and about 17-18VDC. I can not whe...
hi I am not able to download stm32cubemx on desktop
Helo,I have recently bought a STEVAL-IPFC01P1, to evaluate de STNRGPF01 controller.I want input voltage spec to 90-265VAC at 47-63Hz rangeHow can I change it?I'm tried the following way...1) Interleaved PFC Specifications clock2) "Mains Wide Range Li...
I've been tried to looking for a detail description of the uC mode in regards of the enable pins, but I couldn't. That's the reason of my questions.
Hi, I am currently attempting to create a development board stack up starting with a Nucleo-f401re, GNSS1A1, IKS01A2, and SX1276MB1LAS LoRa shield in the order listed. I was having difficulties getting two stack ups to communicate through radio and r...
I have installed this software from ST "Remote Console for GP ST7540" on a few computers running on Windows 7 and on Windows 10 with compatibility mode set to Windows 7 and unable to run the application. On all computers the software installs withou...
Hi,I am currently attempting to create a development board stack up starting with a Nucleo-f401re, GNSS1A1, IKS01A2, and SX1276MB1LAS LoRa shield in the order listed. I was having difficulties getting two stack ups to communicate through radio and r...
