Write memory command in ICC mode for ST7FLITE05
clanuchnik
Posted on December 08, 2004 at 17:36
3 REPLIES 3
clanuchnik
Posted on December 06, 2004 at 11:12
I am looking for an example of how to use the write memory command to set the stack with the address to be used after issuing the Go command
Thanks.............Claudio
jatin
Posted on December 08, 2004 at 12:56
You can download ''ICC protocol reference manual'' or ''ST7 flash programming manual''.
sjo
Have a look in the Flashbash src code, should give you a rough idea.
File to look at is icc.asm function ICCMicroGo
sjo
