What is the internal clock/PLL frequency of the VL53L5CX?
MFabb.1
As noted on the documentation the VL53L5CX could integrate a microcontroller with an internal oscillator/PLL clock source. This could have a high frequency value in order to handle the ns-scale timing of the FlightSense technology and the histograms processing.
I am investigating the EMI spectrum of a product integrating a VL53L5CX and I should consider all the possible noise contributions.
Thank you
John E KVAM
500MHz.
If this or any post solves your issue, please mark them as 'Accept as Solution' It really helps. And if you notice anything wrong do not hesitate to 'Report Inappropriate Content'. Someone will review it.
John E KVAM
500MHz.
