2003-04-14 04:53 AM
unable to read the flash memory contents after programming
2011-05-17 02:53 AM
I am trying to read the flash memory contents after programming the upsd323X using JTAG flash link programmer. I tried to read using ST conventional programmer--upload (one of the option in PSD SOFT EXPRESS) note: the hardware set up is showing ''PSD PRO'' With this steps : i am getting an error message '' upsd 3234 is not currently supported by psd pro'' we have written the code for IAP in C.. but not in a position to test the same ...since we want to know at which location we are wriiting or erasing + how the interrupt remapping is done So can you please help us .... We have very little time to develop the code...so reply soon... purvi2011-05-17 02:53 AM
Purvi:
I have not time to resolve you question because I have not device to do it and I am not PSM Group. I am ST MCU APCC. I have send you question to PSM Group. So you can send your detailed question tomailto:jacky.jia@st.com
2011-05-17 02:53 AM
Thanks alot...
2011-05-17 02:53 AM
The uPSD products CANNOT be programmed or read using a conventional programmer. The uPSD ONLY works with JTAG programming! There are several programmers that support JTAG, please check out the www.st.com/micropsd web site for info
on JTAG programmers.
