TIM1 and TIM on STR712
ludo98
Posted on May 02, 2006 at 05:54
2 REPLIES 2
ludo98
Posted on April 28, 2006 at 08:16
Hello, i have a question about the TIM1 and TIM2 of STR712.
i would like to produce a signal with the TIM1 and TIM2 configurated in PWMO mode.
I would like the signal of the ouput of the timer TIM pin.
10
| |_______________
255
following my code:
for PWM0 (TIM1) :
GPIO_Config (GPIO1 , 1<<7, GPIO_AF_PP );
TIM_Init ( TIM1 );
TIM_PrescalerConfig ( TIM1,0x1 );
TIM_PWMOModeConfig ( TIM1, 10, TIM_LOW, 255, TIM_HIGH );
TIM_CounterConfig ( TIM1, TIM_START );
the signal is output is the following:
10
| |_______________
255
for PWM1 (TIM2) :
GPIO_Config (GPIO0 , 1<<13, GPIO_AF_PP );
TIM_Init ( TIM2 );
TIM_PrescalerConfig ( TIM2,0x1 );
TIM_PWMOModeConfig ( TIM2, 10, TIM_LOW, 255, TIM_HIGH );
TIM_CounterConfig ( TIM2, TIM_START );
10
_______________| |
255
the signals are reversed. My question is it's Normal?
Ludovic
ludo98
hello,
thanks for your answer. the problem has been resolved.: at the output of the TIM1 a component( transistor) inverse the signal. now i play an wav file with th TIM1 at 8Khz frequency but have a correct sound but it's a little metal. Have you some advice to reduce this phenomen ?
thanks
since regards
Ludovic
