TCP/IP
gianfranco2
Posted on February 03, 2005 at 13:16
TCP/IP
8 REPLIES 8
gianfranco2
Posted on January 28, 2005 at 06:16
Hi
what do i need to imlement an TCP/IP stack with STR710?
I am looking at porting of uCLinux with TCP/IP functionality and the STE10/100 device.
I would like to know if are there different way and more easy respect this.
Tks
mohamed23
Posted on January 28, 2005 at 09:35
Hi dimarcog,
I'am very interested by your application, Could You please
inform us what kind of design or development of TCP/IP on STR710 ? How will you connect STE10/100 ? If you Need 10Mbits
or 100Mbits baud rate ?....
But It seems to me that STE10/100 is a bit complex to connect to
STR710 as it has a PCI bus interface !
With Regards, :-]
[ This message was edited by: Rave on 28-01-2005 14:06 ]
[ This message was edited by: Rave on 28-01-2005 14:07 ]
gianfranco2
Posted on January 31, 2005 at 14:35
I guess there are very very interest around the TCP/IP implementation on STR7.
I hope the moderators give us the information needed or other information in order to use STE or a different devices or solution.
per239955_st
Posted on February 01, 2005 at 08:32
I've just got my hardware (own design, not eval board) and is starting currently it up.
We (the company I work for) have choosen the Davicom DM9000 as ethernet controller. It has a standard ISA bus which is very easy to interface to the ARM.
I'm planning to use the lwIP TCP/IP stack which is an open source solution.
http://savannah.nongnu.org/projects/lwip/
/Beach/
gianfranco2
Posted on February 02, 2005 at 15:25
Hi Beach,
the DM9000 is very interest.
Regarding IwIP TCP/IP stack you have to make the porting for ARM. May be to easy to use a uCLinux porting in order to reuse the Linux driver for DM9000, am I right?
hsanchez
Posted on February 03, 2005 at 10:37
Hi.
I think uCLinux is the best option, not just for reuse, but for what you can do after you have uCLinux running (gcc, tcp/ip stack, file system, etc).
Hernán Sánchez
mohamed23
Posted on February 03, 2005 at 11:02
RealTek RTL8019 and Cypress CY8900 Ethernet Controller seem also very simple to connect with STR710 EMI Interface (16-bits),
kind regards, :p
per239955_st
Just for clarification. I'm planning to use the lwIP TCP/IP stack and not uCLinux because I only want/need the TCP/IP stack.
I dont need all the other OS stuff in the current project.
Maybe I will have a look at the 'low_level' stuff in the DM9000 driver for the uCLinux to see how to initialize the chip.
/Beach
