2024-09-28 8:33 PM
I want a stable version sys_arch.c and sys_arch.h based on µC/OS-III, LwIP only provide example for FreeRTOS.
I found follow example, please help to optimize it, thanks
#define SYS_ARCH_GLOBALS
/* lwIP includes. */
#include "lwip/debug.h"
#include "lwip/def.h"
#include "lwip/sys.h"
#include "lwip/mem.h"
#include "lwip/timeouts.h"
#include "lwip/tcpip.h"
#include "includes.h"
#include "delay.h"
#include "sys_arch.h"
#include "malloc.h"
#include <os_cfg_app.h>
const void * const pvNullPointer = (mem_ptr_t*)0xffffffff;
err_t sys_mbox_new( sys_mbox_t *mbox, int size)
OS_ERR err;
(*mbox)=mymalloc(SRAMIN,sizeof(TQ_DESCR));
my_mem_set((*mbox),0,sizeof(TQ_DESCR));
(*mbox)->pQ=mymalloc(SRAMIN,sizeof(OS_Q));
my_mem_set((*mbox)->pQ,0,sizeof(OS_Q));
if(*mbox&&(*mbox)->pQ)
if(size>MAX_QUEUE_ENTRIES)
size=MAX_QUEUE_ENTRIES;
OSQCreate((*mbox)->pQ,"lwip_mbox",size,&err);
LWIP_ASSERT("OSQCreate",err==OS_ERR_NONE);
if(err==OS_ERR_NONE)
return ERR_OK;
else
myfree(SRAMIN,(*mbox));
return ERR_MEM;
}else return ERR_MEM;
void sys_mbox_free(sys_mbox_t * mbox)
OS_ERR err;
sys_mbox_t m_box=*mbox;
OSQDel(m_box->pQ,OS_OPT_DEL_ALWAYS,&err);
LWIP_ASSERT( "OSQDel ",err == OS_ERR_NONE );
myfree(SRAMIN,m_box);
*mbox=NULL;
void sys_mbox_post(sys_mbox_t *mbox,void *msg)
OS_ERR err;
OS_MSG_SIZE msg_size;
if(msg==NULL)
msg=(void*)&pvNullPointer;
msg_size = (OS_MSG_SIZE)sizeof(msg);
do {
OSQPost((*mbox)->pQ,(void*)msg,msg_size,OS_OPT_POST_ALL,&err);
} while(err!=OS_ERR_NONE);
err_t sys_mbox_trypost(sys_mbox_t *mbox, void *msg)
OS_ERR err;
if(msg==NULL)
if(err!=OS_ERR_NONE)
return ERR_MEM;
return ERR_OK;
u32_t sys_arch_mbox_fetch(sys_mbox_t *mbox, void **msg, u32_t timeout)
OS_ERR err;
u32_t ucos_timeout,timeout_new;
void *temp;
if(timeout!=0)
ucos_timeout=(timeout*OS_CFG_TICK_RATE_HZ)/1000;
if(ucos_timeout<1)
ucos_timeout=1;
else
ucos_timeout = 0;
timeout = OSTimeGet(&err);
temp=OSQPend(m_box->pQ,
(OS_TICK)ucos_timeout,
OS_OPT_PEND_BLOCKING,
&msg_size,
(CPU_TS *)0,
&err);
if(msg!=NULL)
if(temp==(void*)&pvNullPointer)*msg = NULL;
else *msg=temp;
if(err==OS_ERR_TIMEOUT)timeout=SYS_ARCH_TIMEOUT;
else
LWIP_ASSERT("OSQPend ",err==OS_ERR_NONE);
timeout_new=OSTimeGet(&err);
if (timeout_new>timeout) timeout_new = timeout_new - timeout;
else timeout_new = 0xffffffff - timeout + timeout_new;
timeout=timeout_new*1000/OS_CFG_TICK_RATE_HZ + 1;
return timeout;
u32_t sys_arch_mbox_tryfetch(sys_mbox_t *mbox, void **msg)
return sys_arch_mbox_fetch(mbox,msg,1);
int sys_mbox_valid(sys_mbox_t *mbox)
//u8_t ucErr;
int ret;
//OS_Q_DATA q_data;
//memset(&q_data,0,sizeof(OS_Q_DATA));
//ucErr=OSQQuery (m_box->pQ,&q_data);
ret=(/*ucErr<2&&*/(m_box->pQ->MsgQ.NbrEntries<m_box->pQ->MsgQ.NbrEntriesSize))?1:0;
return ret;
void sys_mbox_set_invalid(sys_mbox_t *mbox)
*mbox=NULL;
err_t sys_sem_new(sys_sem_t * sem, u8_t count)
OS_ERR err;
(*sem)=mymalloc(SRAMIN,sizeof(OS_SEM));
my_mem_set(*sem,0,sizeof(OS_SEM));
LWIP_ASSERT("OSSemCreate ",*sem != NULL);
if(*sem)
OSSemCreate(*sem,"LWIP Sem",(u16_t)count,&err);
return ERR_OK;
else
return ERR_MEM;
else
return ERR_MEM;
u32_t sys_arch_sem_wait(sys_sem_t *sem, u32_t timeout)
OS_ERR err;
u32_t ucos_timeout, timeout_new;
if(timeout!=0)
ucos_timeout = (timeout * OS_CFG_TICK_RATE_HZ) / 1000;
if(ucos_timeout < 1)
ucos_timeout = 1;
}else
ucos_timeout = 0;
OSSemPend (*sem,(u16_t)ucos_timeout,OS_OPT_PEND_BLOCKING,NULL,&err);
if(err == OS_ERR_TIMEOUT)
else
timeout_new = OSTimeGet(&err);
if (timeout_new>=timeout)
else
timeout = (timeout_new*1000/OS_CFG_TICK_RATE_HZ + 1);
return timeout;
void sys_sem_signal(sys_sem_t *sem)
OS_ERR err;
OSSemPost(*sem, OS_OPT_POST_ALL, &err);
void sys_sem_free(sys_sem_t *sem)
OS_ERR err;
(void)OSSemDel(*sem,OS_OPT_DEL_ALWAYS,&err);
if(err!=OS_ERR_NONE)LWIP_ASSERT("OSSemDel ",err==OS_ERR_NONE);
*sem = NULL;
int sys_sem_valid(sys_sem_t *sem)
//OS_SEM_DATA sem_data;
//return (OSSemQuery (*sem,&sem_data) == OS_ERR_NONE )? 1:0;
sys_sem_t sem_t = *sem;
if (sem_t == NULL) {
return 0;
if (sem_t->Type != OS_OBJ_TYPE_SEM) { /* Validate event block type */
return 0;
return 1;
void sys_sem_set_invalid(sys_sem_t *sem)
*sem=NULL;
void sys_init(void)
extern CPU_STK * TCPIP_THREAD_TASK_STK;
extern OS_TCB tcpip_thread_tcb;
sys_thread_t sys_thread_new(const char *name, lwip_thread_fn thread, void *arg, int stacksize, int prio)
OS_ERR err;
CPU_SR_ALLOC();
if(strcmp(name,TCPIP_THREAD_NAME)==0)
OS_CRITICAL_ENTER();
OSTaskCreate((OS_TCB * )&tcpip_thread_tcb,
(CPU_CHAR * )name,
(OS_TASK_PTR )thread,
(void * )arg,
(OS_PRIO )prio,
(CPU_STK * )&TCPIP_THREAD_TASK_STK[0],
(CPU_STK_SIZE)stacksize/10,
(CPU_STK_SIZE)stacksize,
(OS_MSG_QTY )0,
(OS_TICK )0,
(void * )0,
(OS_OPT )OS_OPT_TASK_STK_CHK|OS_OPT_TASK_STK_CLR,
(OS_ERR * )&err);
OS_CRITICAL_EXIT();
return 0;
err_t sys_mbox_trypost_fromisr(sys_mbox_t *mbox, void *msg) {
OS_ERR err;
OSQPost(m_box->pQ, msg, 0, OS_OPT_POST_FIFO, &err);
if (err == OS_ERR_NONE) {
return ERR_OK;
} else {
return ERR_MEM;
void sys_mutex_lock(sys_mutex_t *mutex) {
OS_ERR err;
OSMutexPend((OS_MUTEX *)*mutex, 0, OS_OPT_PEND_BLOCKING, NULL, &err);
void sys_mutex_unlock(sys_mutex_t *mutex) {
OS_ERR err;
OSMutexPost((OS_MUTEX *)*mutex, OS_OPT_POST_NONE, &err);
err_t sys_mutex_new(sys_mutex_t *mutex) {
OS_ERR err;
*mutex = mymalloc(SRAMIN, sizeof(OS_MUTEX));
if (*mutex != NULL) {
OSMutexCreate((OS_MUTEX *)*mutex, "LwIP Mutex", &err);
return ERR_OK;
return ERR_MEM;
void tcpip_thread(void *arg) {
OS_ERR err;
tcpip_init(NULL, NULL);
while (1) {
sys_check_timeouts();
OSTimeDlyHMSM(0, 0, 0, 100, OS_OPT_TIME_DLY, &err);
void tcpip_thread_init(void) {
OS_ERR err;
OS_TCB *tcb = mymalloc(SRAMIN, sizeof(OS_TCB));
void *stack = mymalloc(SRAMIN, TCPIP_THREAD_STACKSIZE);
OSTaskCreate(tcb, "TCP/IP Task", tcpip_thread, NULL, TCPIP_THREAD_PRIO,
stack, TCPIP_THREAD_STACKSIZE/10, TCPIP_THREAD_STACKSIZE, 0, 0, NULL,
OS_OPT_TASK_STK_CHK | OS_OPT_TASK_STK_CLR, &err);
if (err != OS_ERR_NONE) {
2024-09-29 1:01 AM
