2004-04-12 05:05 PM
2004-04-09 09:56 AM
Hello !
I have a problem with STVP (ST7 Visual Programmer). When I use it at my office, it works correctly on Windows NT. At home, I installed it and it doesn't work (on Windows XP). I have the message ''Error : Problem while downloading monitor''. Have you an idea to resolve my problem ? Thanks.2004-04-12 05:05 PM
Are you using the the same hardware set-up in both cases?
What is the device you are programming? I have seen the problem once when programming in ICP mode and there was a problem of device detecting the clock.
