Strap options for CPU Clock Multiplication (486 mode) - Atlas
mdesjardine
Posted on September 18, 2003 at 13:33
3 REPLIES 3
mdesjardine
Posted on September 10, 2003 at 20:19
What happens if you have MD[14] = 0 and MD[40] = 1 on an Atlas? The datasheet indicates that this is a reserved setting. Any idea of what this reserved setting does and what speed the system will run at? Can it be used with HCLK = 66 MHz?
davidbellegarde9
Posted on September 17, 2003 at 06:53
The settings that you describe is for x3 mode but it cannot be used with HCLK=66MHz.
stephen239955_st
Please be advized that the STPC Atlas does not support these multiplication factors and if they are selected will not be work reliably.
