2007-06-04 04:43 AM
st7540 problem
#power-line #test #st75402007-05-28 07:53 AM
Hallo,
I made an project with ST7540, i have problem with sending data in UART mode. Because, i can't look my result in TxOut pin with oscilloscope. Is there anyone know how to solve this problem. Because, i really need your help. I already send an e-mail into ST contact support, but until know they didn't reply me. Thank you, Yoga2007-06-04 04:43 AM
Thank you for using STMicroelectroinics products and website. This forum is dedicated to ST7 microcontrollers. Concerning non microcontroller products (like ST7540, ST7538x, ...), you will get a better support by contacting our technical support : http://www.st.com/stonline/domains/support/contact_support.htm Best regards Laurent2012-10-31 04:39 AM
Hi, I'm using the ST7540 for a little system of 2 computers, after two weeks I finally accomplished read, write, and send information. But one day, the PA (Power amplifier) stop working, so, the control loops start to working and needs more and more voltage and current, I don't know how it damage, but The ST7540 Have two test pin and I want to test it, but there's no word in the datasheet about how work those pins (27 and 28), can you explain me how?.
Thanks a lot. Greetings from Venezuela.
