2006-04-05 06:08 AM
2006-04-05 02:24 AM
Hi all !
I have a problem when using the ICC interface on ST72F324J6B5: When using the internal RC oscillator both Osc1(pin35) and Osc2(pin34) should be tied to ground - says the manual. During programming - Osc1 should be connected to pin 9 of the ICC connector ( HE10 ) and not to ground. I am using ST7 Flash Stick and latest STVP7 v.2.0 software. Is there anyway , except a separate jumper, to solve this problem ? Thanks in advance. BR Tomas
