ST7 Linker - rel 3.18 ERROR
schaeublinconsu
Posted on November 25, 2009 at 12:04
1 REPLY 1
schaeublinconsu
Hi
With the newer releases STVD I get problems with the following declarations
segment 'ram0'
com1 segment common 'ram0'
.dividend DS.L 1; (div_lxw used in maths.asm)
.add_a DS.W 1 ; (addw used in maths.asm)
I receive the following error message:
200K namespace for approx 8150 publics
** Error : segment C:\.....\constant.asm:'ram0' [0xf7 - 0xfa] and segment C:\.......\constant.asm:'ram0' [0xf7 - 0xf8] overlap
The command: ''lyn debug\mapping.obj+Debug\st72344.obj+Debug\constant.obj+Debug\main.obj+Debug\subr.obj+Debug\disp.obj+Debug\math.obj, Debug\dcf_555.cod, '' '' '' has failed, the returned value is: 2
exit code=2.
Why ?
Thanks in advance
Hansjusch
