st10flasher.lib for new flasher DLL
thomaskobler9
Posted on June 29, 2006 at 06:27
4 REPLIES 4
thomaskobler9
Posted on June 07, 2006 at 07:09
Does anyone know how to get the st10flasher.lib to the st10flasher.dll of the 2.4B flasher tool? Even our Distributor seems unable to get it.
It is needed to recompile our command line 'frontend' to the DLL. For the old Flasher there was a 'DevelopmentKit' with examples and the linker library:
Verzeichnis von E:\Programme\STM\ST10Flasher\DevelopmentKit
06.12.2005 15:09 <DIR> .
06.12.2005 15:09 <DIR> ..
31.05.2001 15:03 6.472 basicinterface.h
06.12.2005 15:09 <DIR> CPP_Sample
31.05.2001 15:02 4.621 Dll_interface.bas
31.05.2001 15:03 75.170 st10flasher.exp
31.05.2001 15:03 126.516 st10flasher.lib <- linker lib
4 Datei(en) 212.779 Bytes
Verzeichnis von E:\Programme\STM\ST10Flasher\DevelopmentKit\CPP_Sample
31.05.2001 15:03 1.206 ReadMe.txt
31.05.2001 15:03 3.075 Samples.cpp
31.05.2001 15:03 4.643 Samples.dsp
31.05.2001 15:03 621 Samples.dsw
31.05.2001 15:03 295 StdAfx.cpp
31.05.2001 15:03 707 StdAfx.h
6 Datei(en) 10.547 Bytes
Is there an update to this, too?
Thank you..
thomaskobler9
Posted on June 08, 2006 at 10:44
Does somebody have documentation on the flasher DLL? Or code examples how to call it directly from 'C' without the linker lib?
Thank you.
thomaskobler9
The original post was too long to process during our migration. Please click on the provided URL to read the original post. https://st--c.eu10.content.force.com/sfc/dist/version/download/?oid=00Db0000000YtG6&ids=0680X000006I6hz&d=%2Fa%2F0X0000000bti%2FwJxyviCtWDKVgcnXD2ig0WLwhYHs7JxHlFoVvyCilPo&asPdf=false
jayesh
Posted on March 31, 2010 at 22:31
We are getting similar error
How did you solve this error
Pls guide us
Thnx
