ST10F276 Flash
mondher
Posted on October 15, 2004 at 04:43
ST10F276 Flash
mondher
Posted on October 14, 2004 at 17:49
Hello
I want to program the flash of the ST10F276 using the flash registers, but my problem is that I read in the memory values different of the values that I had written. What could be the problem?
Thanks,
najoua
I had nearly the same problem. The data that you had read may be read from another memory and not from the flash.
Check That :
- ROMEN bit in SYSCON register is set .
- Verify that XFLASHEN bit in XPERCON register is set in order to be able to access the Flash Control Register
I hope this will help you.
[ This message was edited by: Najoua on 15-10-2004 09:31 ]
[ This message was edited by: Najoua on 22-01-2007 11:58 ]
