ST10F269 flash
gaby_bradu
Posted on March 12, 2007 at 12:12
ST10F269 flash
6 REPLIES 6
gaby_bradu
Posted on March 08, 2007 at 14:47
I can not find my mistake. I want to clear the Int. flash & it does not work.
May somebody have a look in my code?
The code is executed from RAM, it's ok.
Thanks a lot.
Gabi
mkC ST10F269
[ This message was edited by: gaby_bradu on 08-03-2007 19:19 ]
:o Sometimes there are very simple errors.
It Works.
[ This message was edited by: gaby_bradu on 09-03-2007 09:59 ]
________________
Attachments :
erase.txt : https://st--c.eu10.content.force.com/sfc/dist/version/download/?oid=00Db0000000YtG6&ids=0680X000006I0M4&d=%2Fa%2F0X0000000bXp%2FYnJsO25iXiCbb1JXMY8xvkyBJyVs3rxbsYiySUwSbc8&asPdf=false
gaby_bradu
Posted on March 09, 2007 at 11:04
Thanks Neila,
ROMEN = 1
ROMS = 0
R8&9 - (0/0; 0/4; 0/6; 1/0; 2/0...)
It works for the Bank 0 R8&R9 = 0. (deletes my software :))
My controler goes through reset if I call the function below, on this point:
MOV [R5],R7
Is something wrong configured?
Thanks a lot,
Gabi.
PFlash_RP PROC NEAR
MOV R1, #2H ; The second page
MOV R5, #02A54H ; For the 1st & 3rd write
MOV R6, #015A8H ; For the 2nd write
MOV R2, #0A8H ;
MOV R3, #54H ;
MOV R7, #90H ;
EXTS R1, #4
MOV [R5],R2 ; 1st command
MOV [R6],R3 ; 2nd command
MOV [R5],R7 ; 3rd command
MOV R4,[R1] ; 4th command
RET
PFlash_RP ENDP
[ This message was edited by: gaby_bradu on 09-03-2007 15:36 ]
[ This message was edited by: gaby_bradu on 09-03-2007 15:45 ]
gaby_bradu
Posted on March 12, 2007 at 07:30
Hi Neila,
Thank you for your help.
The WDTCON register I did not read. The following hardware traps are analysed in my software & no one comes:
void NMI_trap (void) interrupt 0x02{...trap_cause = TFR;...}
void STKOF_trap (void) interrupt 0x04{...trap_cause = TFR;...}
void STKUF_trap (void) interrupt 0x06{...trap_cause = TFR;...}
void Class_B_trap (void) interrupt 0x0A{...trap_cause = TFR;...}
But I'll check all this points once more & I'll be back soon.
Thanks a lot.
Gaby.
8-)
gaby_bradu
Posted on March 12, 2007 at 10:36
So I'm back, I did some tests......
it was the watchdog, after the RP function and it restarts I read 0x06. But it can not be because I service the WD. I disabled the WD
DISWDT
EINIT
and now it hangs-up. :(
I did a small change in the RP procedure and it never returns:
EXTS R1, #3
RET
The generated code from RP function is:
:10300000E021E6F5542AE6F6A815E6F2A800E6F374
:103010005400E6F79000DC21B825B836B875CB002F
:04302000A841CB00F8
After the instruction B875 it hangs-up.
Thanks,
Gaby.
P.S. I copy this code on address 0xC000 (or 0xE000), it's free.
int (*PFlash_RPP)(void);
PFlash_RPP = (void *)0xC000;
xmemcpy((ubyte huge *)PFlash_RPP, (ubyte huge *)PFlash_RP, 80);
tst = PFlash_RPP();
[ This message was edited by: gaby_bradu on 12-03-2007 15:55 ]
gaby_bradu
Posted on March 12, 2007 at 11:46
Hi Neila,
I send the sources on your e-mail (neila_kraiem@yahoo.fr). The rest you can see from the code.
Thanks,
Gaby.
gaby_bradu
My e-mail is:
mailto:gaby_bradu@yahoo.com
Gaby.
