St10 User stack
Posted on October 31, 2007 at 09:48
St10 User stack
Posted on October 31, 2007 at 05:44
Hi all,
I have a question about ST10 user stack.
In my linker file, I located it at 0xF0100, size 0x2000; so from 0xF0100 to 0xF20FF
In my startup file, I can see the user stack init :
MOV R0,#DPP2:?C_USERSTKTOP
... but since R0 is a 16 bit register, the value may be truncated... When I run the simulator, after this MOV instruction, the updated R0 value is 0xA100... My target works fine but I can't understand this 0xA100 value.
Could you explain me ?
Thanks a lot !
Pierre
PS : I am using a ST10F276
[ This message was edited by: pierre.roth on 31-10-2007 10:20 ]
OK I found an explanation about DPP registers.
User stack is located in NEAR memory which is accessed using DDP2.
Therefore I think my R0 value is understandable :
Stack located from 0xF0100 to 0xF20FF.
R0 Value :
Hex : A 1 0 0
Bin : 1010 0001 0000 0000
so DPP is 10 (bit 15-14) which is DDP2.
DPP2 contains 0x3C and 0x3C * 4 = 0xF0 !!
