2004-10-01 04:30 AM
ST10 Flasher and resetting the target
2004-09-30 07:12 AM
I am using the ST10Flasher DLL to build my own loader program for a ST10F269. Once reflashed, I would like to reset the target so the newly flashed program starts executing.
ANyone have any ideas as to how I might be able to do that? Thanks2004-09-30 09:57 PM
Before running the ST10Flasher, switch ON the bootstrap loader. Then program the flash. After the programming was successful, switch OFF the bootstrap loder and ON the single chip mode. Then, reset the controller. If every thing is working properly, your program starts executing.
