software PWM
bleumers_j
Posted on June 24, 2004 at 02:25
software PWM
5 REPLIES 5
bleumers_j
Posted on June 22, 2004 at 07:36
I'm trying to generate code in a cheap ST7LITE09 with 3 sofware PWM's. But it doesn't work and i can't find the mistake.
Any idea's.
This is the code:
#include ''Io7FLite0.h'' // ST7Flite0 memory and registers mapping
#include ''lib_bits.h'' // Predifined libraries working at bit level
#include ''bitdef.h'' // This file defines the names of the bits
int tijd,teller;
int pwm1,pwm2,pwm3;
void main(void)
LTCSR=0x10;
ATCSR=0x12;
PBDDR=0x07;
PBOR=0x07;
PBDR=0x00;
teller = 0;
pwm1 = 125; // write testvalue into pwm (50% dutycycle)
pwm2 = 125;
pwm3 = 125;
_asm(''rim'');
while(0)
@interrupt void AR_timer(void)
if (teller == 0)
SetBit(PBDR,0);
SetBit(PBDR,1);
SetBit(PBDR,2);
if (teller == pwm1)
ClrBit(PBDR,0);
if (teller == pwm2)
ClrBit(PBDR,1);
if (teller == pwm3)
ClrBit(PBDR,2);
teller++;
tijd = ATCSR; // Reset timer flag
Thanks in advance!
sjo
Posted on June 22, 2004 at 10:14
Below is a simple 3 channel pwm - freq 192Hz 0-100Duty.
Alter the g_cCounter reload value to adjust resolution/speed, eg.
change reload g_cCounter with 20 will alter pwm freq to approx 960Hz, the resolution will be much less - 20 steps rather than 100.
Adjust to suit your project.
unsigned char g_cCounter;
counter for motor pwm
volatile unsigned char g_cPwms[3]; // Motor PWM speeds
void main(void)
g_cPwms[0] = 50;
g_cPwms[1] = 30;
g_cPwms[2] = 50;
g_cCounter = 0;
ATR = 0xE5F;
ATCSR = 0x12;
PBDDR=0x07;
PBOR=0x07;
PBDR=0x00;
rim();
while(1);
if( g_cCounter >= g_cPwms[0] )
ClrBit( PBDR, 0 );
else
SetBit( PBDR, 0 );
if( g_cCounter >= g_cPwms[1] )
ClrBit( PBDR, 1 );
else
SetBit( PBDR, 1 );
if( g_cCounter >= g_cPwms[2] )
ClrBit( PBDR, 2 );
else
SetBit( PBDR, 2 );
if( ++g_cCounter >= 100 )
g_cCounter = 0;
ATCSR; // clear OVF flag
One point to remember as this device does not have nested interrupts, the ar timer interrupt is low priority - any other interrupt will seriously interfere with the software pwm above.
sjo
[ This message was edited by: sjo on 22-06-2004 13:49 ]
luca239955_st
Posted on June 22, 2004 at 12:23
one important difference between sjo's code and yours (although I'm not sure that's where your problem is coming from) is the use of the ''volatile'' keyword. More details at http://www.stmcu.com/forums-cat-1665-1.html
Luca
[ This message was edited by: _luca on 22-06-2004 15:53 ]
bleumers_j
Posted on June 23, 2004 at 05:44
I have changed my code in the interrupt module to the code Sjo gave, and it works!
I think the problem was that when i write 'teller++' and teller = 255, it does not become 0 (as i thought), but it stays
I'm not sure this is the cause of the trouble, but i'll experiment with it when i have more time.
Thanks for your help!!!
huaer2000
sjo,
If I want to make the PWM frequency higher to 10K/20K, if your software can
do this?
best regards
mcuinterest
