2007-05-08 11:01 PM
really need keil ULINK cable to program via ISP my uPSD3422EV?
2011-05-17 02:51 AM
Hello
I use Keil tool to program. I recently bought a rfid dev kit containing a uPSD3422EV. I am new in ST environment and I d like to know if I really need to buy the Keil ULink cable to be able to program (via ISP) my ST microcontroller? Is there any cheaper way (or cable) to do the same? :o Thank you in advance for your time. Regards fabrice2011-05-17 02:51 AM
2011-05-17 02:51 AM
Thanks a lot for your reply! :)
I will check if there is a programming adapter once I get the dev kit (should be this week my supplier told me). If not I will buy the ULINK adapter. Concerning ''resident code that will erase/write the flash with your new code'' you mentionned, do you know where i could get an example of this kind of code? Have a good day! fabrice2011-05-17 02:51 AM
2011-05-17 02:51 AM
Thanks a lot for your help and these good advices!
I really appreciate fabrice
