quartz for RTCXTI
dmerchez9
Posted on May 03, 2005 at 13:37
quartz for RTCXTI
dmerchez9
Posted on May 03, 2005 at 08:32
Hello
I've seen that between the RTCXTI et RTCXTO pins, we have to place a 32KHz quartz for the realtime clock.
If if generate this clock by a FPGA, is it possible to connect this signal on the RTCXTI pin, and to put the RTCXTO one on the ground?
If not, is there a solution?
Thx
Dam :D
hichem2
Hello Dam,
In the STR71x Reference Manual (Page 63/345) it's indicated that you can stopped or bypassed the 32-KHz oscillator , featuring zero power consumption and allowing an external reference clock to feed the Real Time Clock, or a
Backup clock source to the whole system.
So I think that your idea is actable.
Best regards,
Hich ;)
[ This message was edited by: Hich on 03-05-2005 17:27 ]
