programming the ST72F264 Using the ST7 IN DART
adi2
Posted on November 17, 2003 at 09:17
adi2
Posted on November 17, 2003 at 06:19
hi !!
i'm using the ST72F264 DEMO BOARD , the in dart-stx , indart ST7 and the metrowerks as a compiler with the plug in installed.
now i'm trying to program my device but with no success, here are my steps maybe you can help me to verify what i do wrong (or did not do and need to do) :
1. i set the MCU i'm using the MCU configuration menu
2. i set the option byte
3. i load with in the indart the *.abs file
but i get errors like :
gdi-error in indart.
debugging with the metrowerks have no problams so far.
pleade advise.
thanks.
adi.
kr
Posted on November 17, 2003 at 07:07
Are you sure that the selected clock source in the option byte is available in your application ?
adi2
you are right, the clk source was not configure proper.
thanks
