Programming - SVS
shermantec
Posted on July 14, 2003 at 19:07
Programming - SVS
shermantec
Posted on May 17, 2011 at 11:54
Hello All
I need to program the PSD813F1-12JI in Automatic Programmer so i need the get the program file in SVS format .
Is there any progress to do so ?
Latino
joseph2399
Do you mean SVF format? If your answer is yes, you can generate it from PSDsoft Express, under STMicroelectronics JTAG/ISP menu. Click the ''ATE files...'' at the bottom, then select the ''Generate SVF File'' option.
However, if you really mean SVS format, please explain what SVS stand for and what kind format is expected.
