Programer for ARM STR9, Flash PSD, uPSD and DSM. Compatible with FlashLink
okulicz
Posted on May 03, 2008 at 08:37
1 REPLY 1
okulicz
Posted on May 17, 2011 at 09:52
F-LINKcable is a cheap programmer/debugger for ARM microcontrollers STMicroelectronics family. It is compatible with FlashLink JTAG. Programmer is connected to PC through parallel port, connection with target circuit is done through 14-pin FlashLink standard or standard 20-pin JTAG connector by adapter added to programmer.
Features
- Supports STR91x, Flash PSD, uPSD and DSM ARM microcontrollers family from STMicroelectronics.
- Compatible with FlashLink JTAG
- Available free software: CAPS and PSDsoft express
- 14-pin connector for target circuit and standard 20-pin connector by Adapter
- Operates with target voltages in the range of 3 - 5.5 V
- Supplied from the target circuit, no need for external power supply
- Connection with PC through parallel port
Supported devices
- STR9 Family
- Flash PSD Family
- uPSD Family
- DSM Family
http://www.propox.com/products/t_181.html?lang=en
:o :o :o :o :o :o :o :o :o
[ This message was edited by: okulicz.andrzej on 03-05-2008 12:08 ]
