2008-05-02 09:35 AM
2011-05-17 12:52 AM
* Function Name : VIC_GetISRVectAdd * Description : Get the ISR vector address of the correspondent line. * Input : VIC_Source: specifies the number of the source line. * This parameter can be one of the following values: * - WDG_ITLine : VIC source 0 * - SW_ITLine : VIC source 1 * - ARMRX_ITLine : VIC source 2 * - ARMTX_ITLine : VIC source 3 * - TIM0_ITLine : VIC source 4 * - TIM1_ITLine : VIC source 5 * - TIM2_ITLine : VIC source 6 * - TIM3_ITLine : VIC source 7 * - USBHP_ITLine : VIC source 8 * - USBLP_ITLine : VIC source 9 * - SCU_ITLine : VIC source 10 * - ENET_ITLine : VIC source 11 * - DMA_ITLine : VIC source 12 * - CAN_ITLine : VIC source 13 * - MC_ITLine : VIC source 14 * - ADC_ITLine : VIC source 15 * - UART0_ITLine : VIC source 16 * - UART1_ITLine : VIC source 17 * - UART2_ITLine : VIC source 18 * - I2C0_ITLine : VIC source 19 * - I2C1_ITLine : VIC source 20 * - SSP0_ITLine : VIC source 21 * - SSP1_ITLine : VIC source 22 * - LVD_ITLine : VIC source 23 * - RTC_ITLine : VIC source 24 * - WIU_ITLine : VIC source 25 * - EXTIT0_ITLine: VIC source 26 * - EXTIT1_ITLine: VIC source 27 * - EXTIT2_ITLine: VIC source 28 * - EXTIT3_ITLine: VIC source 29 * - USBWU_ITLine : VIC source 30 * - PFQBC_ITLine : VIC source 31 * Output : None * Return : The correspondent ISR vector address. *******************************************************************************/ u32 VIC_GetISRVectAdd(u16 VIC_Source) { if (VIC_Source < VIC_REGISTER_NUMBER) /* VIC0 */ return VIC0->VAiR[VIC_Source]; else /* VIC1 */ return VIC1->VAiR[VIC_Source - VIC_REGISTER_NUMBER]; } Should be * Input2 : VIC_Priority: specifies the priority of the interrupt. · It can be a value from 0 to 15. 0 is the highest priority. u32 VIC_GetISRVectAdd(u16 VIC_Source , u16 VIC_Priority) { if (VIC_Source < VIC_REGISTER_NUMBER) /* VIC0 */ return VIC0->VAiR[VIC_Priority]; else /* VIC1 */ return VIC1->VAiR[VIC_Priority]; }
