Problem with pointer
tech4
Posted on July 25, 2003 at 08:05
9 REPLIES 9
tech4
Posted on July 17, 2003 at 10:59
segment 'rom'
.data DC.W Hello
.Hello DC.B ''Hye'',0
.main
ld A,([data.w],X)
Error 54: Can't match Addressing mode
What is wrong, please ?
[ This message was edited by: Padb on 17-07-2003 14:32 ]
simonharrison9
Posted on July 17, 2003 at 14:51
Hi
use LD A, (data,X)
The [xx.w] version refers to a 16 bit address location in zero space memory.
The programming manual available from the download section of this site covers this very well.
ensure there is no space between the , and the X on all instructions
regards,
Simon
simonharrison9
Posted on July 17, 2003 at 14:56
I just read it again. sorry......
declare it in RAM:
segment 'ram0'
.data ds.w Hello
segment 'rom'
.main
ld A,([data.w],X)
You can then change the ram locations to point to different arrays/strings and scan through the string using X
Simon
tech4
Posted on July 18, 2003 at 11:17
''constant.asm''
segment 'ram0'
WORDS
.data DS.W HELLO ;Pointeur sur Hello
segment 'rom'
.HELLO DC.B ''Hye'',0
''Constant.INC''
EXTERN data.w
EXTERN HELLO.w
''Myprogram.ASM''
#INCLUDE ''ST72F324.inc'' ; ST72F324 registers and memory mapping file
#INCLUDE ''constant.inc'' ; Définition des constantes
ld A,([data.w],X)
constant.asm(50): as1 : Fatal 97: DS.n length is extern/relative derived, must be absolute '.data DS.W HELLO
Please, what's the matter ???
sjo
Posted on July 18, 2003 at 12:05
Hi there,
You are not setting up your pointer, try this
segment 'ram0'
.data DS.W 1
WORDS
segment 'rom'
.HELLO DC.B ''hello'',0
ld A, #HELLO.h
ld data, A
ld A, #HELLO.l
ld {data+1}, A ; setup pointer to our data
clr X
ld A, ([data.w],X) ; A holds first char of data
do you need tio use a pointer you could do:
clr X
ld A, (HELLO,X) ; without a pointer
Hope this helps
SJO
tech4
Posted on July 25, 2003 at 06:02
WORDS
.pointer DS.W 1 ;
segment 'rom'
.HELLO DC.B ''Bonjour'',0
ld A,#HELLO.h
ld pointer,A
ld A,#HELLO.l
ld {pointer+1},A ; setup pointer to our data
clr X
ld A,([pointer.w],X) ; A holds first char of data
as1 : Error 54: Can't match Addressing mode ' ld A,([pointer.w],X)
simonharrison9
Posted on July 25, 2003 at 06:38
You need to do it this way:
WORDS
segment 'rom'
clr X
ld A,(HELLO,X) ; A holds first char of data
Simon
Anglia
sjo
Posted on July 25, 2003 at 07:22
You have received that warning because you used WORDS rather than BYTES eg.
BYTES
.pointer DS.W 1 ;
WORDS
segment 'rom'
ld A,#HELLO.h
ld pointer,A
ld A,#HELLO.l
clr X
SJO
tech4
You are a champion !!!
