Problem with bootloader
hjn
Posted on May 27, 2009 at 09:55
1 REPLY 1
hjn
Posted on May 17, 2011 at 09:58
Hi
Does anyone here have succes with the bootloader AN 2475 IAP example, using the Hyperterminal?. I'm searching for someone who can help me with a modifyed example that works correct.
If some one here have the source code for a successfully bootloader application, I'm very interested.
I can see some of the others forums is about problems with this bootloader application, but did you solve your problems???.
Looking forward to hear from someone.
Best regards
Hans
