Newbie questions
ronny2
Posted on March 23, 2006 at 08:44
Newbie questions
ronny2
Dear,
I have a Hitex evaluation board with STR710 controller, and the Gnu C compiler, and Hitop programming environment/debugger.
I'm looking for a tutorial/book to start working on this combination (especially on using the gnu C compiler for programming the peripherals of the controller, such as serial port on the demo board). For example, the STR71x Standard Software Library - User Manual does not explain the structure of startup.s... Any suggestions ?
Is there a STR710-consultant in/around Belgium ?
Kind regards,
Ronny
ronny_at_phocon.be
[ This message was edited by: phocon on 23-03-2006 14:28 ]
