Nested interrupts in IAR Embedded Workbench
spektrum_ada
Posted on June 16, 2005 at 14:02
1 REPLY 1
spektrum_ada
Posted on June 16, 2005 at 13:39
Hello
I am using IAR Embedded workbench LE for software development
I found that there is no C library which helps in implementing nested interrupt handler. Can any of you help me and let me know if it is available? I tried to use the assembly code (vector.s) available from ST Micro site. But I am getting lot of errors.
Can somebody tell me what will be the linker file contents in this case?
Is there a separate method to compile assembly files in IAR Embedded workbench?
Shuk
