2007-03-05 08:27 PM
[Need help] Does anyone know how to program str71x without JTAG?
2007-03-04 02:36 PM
Hello everyone,
When I get a str71x from any distributor, there is nothing inside the processor, how can I program user application into the internal flash without JTAG? Or is there any tool supports multiple str71x processors programming at the same time? Thanks for any comment. Dawei2007-03-04 09:50 PM
For multiply off-board programming look at
:)2007-03-05 09:11 AM
The str71 did have a bootloader but it was removed as it did not work correctly.
If the volume is not enough to order preprogrammed parts then the only option is jtag programming. Regards sjo2007-03-05 10:11 AM
Thank you very much for replies.
The multiply off-board programming looks like what I want. By the way, sjo, do you know the rough volume for available programmed parts order? Thanks again. Dawei2007-03-05 08:27 PM
If i remember correctly about 5000 MOQ, usually a NRE charge applies.
You will have to contact your local ST sales office for full details. Regards sjo
