Is there IAP example code available?
shangdawei1
Posted on January 17, 2007 at 05:12
shangdawei1
Posted on May 17, 2011 at 09:35
I need program Bank0 from Bank1.
WBR,
Dawei Shang
najoua
Hello shangdawei,
Yes, ST will provide a driver allowing programming the STR91x Internal Flash Bank0 using In Application Programming via UART.
The IAP driver is to be programmed by the user in the Flash bank 1 after being hardware remapped at address 0x00 (bank 0 is hardware remapped at address 0x80000). Programming is performed via JTAG using a flasher toolset.
Using the UART, the IAP driver loads a binary file from HyperTerminal to the STR9 internal Flash bank 0, and then jumps to execute it.
More details will be provided in the ''STR9 In-Application Programming using UART'' application note which will be published on the web few days later.
Best regards,
Najoua.
najoua
Hello again shangdawei,
Now, the ''STR9 In-Application Programming using UART'' application note (AN2475) and its corresponding software are available on the following web link:
http://www.stmcu.com/modules.php?name=mcu&file=familiesdocs&FAM=101
Best regards,
Najoua. :p
