inline functions
luter
Posted on December 08, 2005 at 06:35
inline functions
luter
Posted on December 05, 2005 at 11:32
Hello.
I try inline fucntion with Cosmic, but get problem.
if i define function and use it in the same file --everything is going well, e.g.
@inline void InLineFunc(void)
Nop;
main ()
InLineFunc();
But if i place call and definition of the inline fuction in different files i am getting error messages. I took into account ''C Cross Compiler User’s Guide'' page 61, but without success.
How should I define this function in .h file or any other suggestions?
Tnx in advance.
fggnrc
Posted on December 06, 2005 at 03:51
Hello Luter.
An inline function is like a pre-processor macro: each call to an inline function is replaced by the function body.
This increases code speed (and code size too).
You can not have a pointer to an inline function and therefore you can not call it from outside of the source file where it is defined.
Bye
EtaPhi
luca239955_st
This may appear obvious, but I thought I would say it anyway:
drawing the conclusion of what EtaPhi says, if you want to use the same inline function in several C files, the only solution is to define it in an header file that is included in all the C files; the definition to use in the header is exactly the same that you would use in the C file (no need for ''extern'' or any other special keyword).
Luca
