IAP _ Trying to write a byte into the main flash while exec form boot flash
tong
Posted on October 08, 2003 at 23:44
3 REPLIES 3
tong
Posted on May 17, 2011 at 11:55
Hi
I need help. Just got the DK3200 kit. I got both com running using int.
Timer...
I am trying to write a byte to the main flash the mapping is:
8000 FFFF _ exactly the same as the one on AN1560
VM = 0x86
FLASH_COMMON_XAAA (volatile unsigned char xdata *) 0x9AAA
FLASH_COMMON_X555 (volatile unsigned char xdata *) 0x9555
FLASH_BOOT_XAAA (volatile unsigned char xdata *) 0x0AAA
FLASH_BOOT_X555 (volatile unsigned char xdata *) 0x0555
I am running the code from the second flash ( program only).
the function to write byte is from from the second flash.
the function to write byte is from flashcode1.c form the code of the usp demo code.
I can't write into the flash. the function return but the byte remain unchanged 0xFF.
To check this I read back by both my code and the upload from the PDSsoftexpress.
Please help !!! _
danielh1
1 - Data read/write signals must be able to access the flash you intend to program, that means that your VM must be set to 0X96.
2 - Since the main flash is paged, set your page register to the flash that you want to access.
3 - All interrupts must be disabled to ensure proper timing of the flash read/write sequences.
Good luck, Asterix
tong
I got it now
VM 0x96
