How to make board recognized by DfuSe Demonstration?
hg-chen
Posted on November 14, 2008 at 09:41
4 REPLIES 4
hg-chen
Posted on May 17, 2011 at 09:47
let ''STM Device in DFU Mode'' appears in Available DFU Device
of DfuSe Demonstration,
amoreno
I have the same question.
How can I do that? where are the code?
Thanks in advance.
ALFA
16-32micros
Hi ,
The code is here :
http://www.st.com/stonline/products/support/micro/files/um0290.zip
Then go to ''str91x demos/Device Firmware Upgrade/project/EWARM'' if you are using IAR version 4.42A and program your board using Jlink and JTAG.
first.
Hope this helps you. ST1 :-)
milton
Hi ! This DfUse application comes with a button to Enter DFU mode/ HID detach and leave DFU mode. Does anyone have a example of a HID firmware with DFU support, I mean a HID/DFU compliant device?
