2006-12-07 03:04 PM
Help!!!! ST712FR2T6 flash programming
2005-08-24 05:03 AM
Hi all,
Compiler-IDE: Keil uVision 3.2 Target: ST712FR2T6 Dev board: Hitex - ST710F JTAG debugger: Keil ULINK I am having a great deal of difficulty programming a ST712FR2T6, we 'appear' to be able access using JTAG without any connection problems, however when trying to erase or program, an error says: Flash timeout, reset target and try again. If we attempt to run from ram, we get a verification error along the lines of offset X value x expected y. I have scoped the lines of the JTAG and all appear very much alike our dev board which works ok. any ideas? Regards, DaveE2006-12-07 03:04 PM
Hello DaveE,
Try to reset[once or twice] your circuit from the RAM mode. Then erase your target[once or twice] in the RAM mode and then try to progarm it in the FLASH mode. I think this may help you out. Cheers, Selva
