2008-01-30 07:54 AM
2008-01-30 02:03 AM
We have upgraded our stvd7 to 3.4.0 and upgraded our projects to new stvd7.
But some of projects the compiler give an error ''unexpected end of file'' and not compile the project. We are changing the project to the another Pc and recompile then it is compiling. Someone has an idea ? Best Regards2008-01-30 07:54 AM
Are you using a makefile to build?
Also is cygwin installed on the problem pc? If you upgrade your project so Visual Develop manages the build then you should get no problems. Regards Spen
