2006-05-31 03:00 AM
Get start with ST7 Visual Developement
2006-05-31 03:00 AM
I'm tring to use STVD7(Visual Developement) instead of the previous STVD7(Visual Debug) these days.When I prush the RUN BUTTON after successfully BUILD and REBUILD,it always says as follows in the OUTPUT WINDOW. Program received signal SIGTRAP, Trace/breakpoint trap. 0x8000 in __stext () The settings and options I have made are listed below. DEBUG TOOL:inDART-STX The third part C compiler:COSMIC C MCU selection:ST7FMC2N6 Programs:BLDC_3PH_SR_2.0 with generated .h files by AK-ST7FMC Control Panel I am looking forward to you help!! thanks
