2008-07-21 12:57 AM
2011-05-17 12:40 AM
Hi all,
I need to send data to codec every 20.8usec. i can't use dma because it would send all the data in go, without regard to the sampling rate. Is there a way to send the data using dma whenever a timer expires? bye vikram2011-05-17 12:40 AM
hi.
i have same problem like you m2m dma application implementation. I cannot solve how can i use dma over memory usage on cortex M3. i wantto use timer2 to use dma channel for copying. but it doesnt work.. please look the code to solve my problem. note: i use dmachannel1 to take values from adg to memory.. i want to dma channel 2 to solve problem with timer 2. but it doesnot working. /* Enable DMA channel2 */ DMA_Cmd(DMA_Channel1, ENABLE); /* DMA channel2 configuration ----------------------------------------------*/ DMA_DeInit(DMA_Channel2); DMA_InitStructure_DMA.DMA_PeripheralBaseAddr = (u16)ADC_ConvertedValue1; DMA_InitStructure_DMA.DMA_MemoryBaseAddr = (u16)ADC_ConvertedValue; DMA_InitStructure_DMA.DMA_DIR = DMA_DIR_PeripheralSRC; DMA_InitStructure_DMA.DMA_BufferSize = 14; // DMA_InitStructure_DMA.DMA_PeripheralInc = DMA_PeripheralInc_Enable; DMA_InitStructure_DMA.DMA_MemoryInc = DMA_MemoryInc_Enable;//Disable;// DMA_InitStructure_DMA.DMA_PeripheralDataSize = DMA_PeripheralDataSize_HalfWord; DMA_InitStructure_DMA.DMA_MemoryDataSize = DMA_MemoryDataSize_HalfWord; DMA_InitStructure_DMA.DMA_Mode = DMA_Mode_Normal; DMA_InitStructure_DMA.DMA_Priority = DMA_Priority_Low; DMA_InitStructure_DMA.DMA_M2M = DMA_M2M_Enable; DMA_Init(DMA_Channel2, &DMA_InitStructure_DMA); /* Enable DMA channel2 */ DMA_Cmd(DMA_Channel2, ENABLE); RCC_AHBPeriphClockCmd(RCC_AHBPeriph_DMA, ENABLE); /* Time base configuration */ TIM_TimeBaseStructure.TIM_Period = 0xFFFF;//0xFFFF;//CCR1_Val;//0xFFFF; TIM_TimeBaseStructure.TIM_Prescaler = 0x000;//0x7CF;//72-1; 0x4e1f;// TIM_TimeBaseStructure.TIM_ClockDivision =TIM_CKD_DIV1; // gerçek ortamdada etkilemedi 🙂 TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up; TIM_TimeBaseInit(TIM2, &TIM_TimeBaseStructure); /* Output Compare Toggle Mode configuration: Channel1 */ TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_Timing; TIM_OCInitStructure.TIM_Channel = TIM_Channel_1; TIM_OCInitStructure.TIM_Pulse = 0xF5B; TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_Low; TIM_OCInit(TIM2, &TIM_OCInitStructure); TIM_OC1PreloadConfig(TIM2, TIM_OCPreload_Disable); /* TIM enable counter */ TIM_Cmd(TIM2, ENABLE); /* TIM IT enable */ TIM_ITConfig(TIM2, TIM_IT_CC1, ENABLE); TIM_DMAConfig(TIM2,TIM_DMABase_CCR1,TIM_DMABurstLength_1Byte); TIM_DMACmd(TIM2,TIM_DMA_CC1,ENABLE); RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM2, ENABLE);
