2006-08-25 07:49 PM
2006-05-26 12:06 AM
Earlier on page (http: // mcu.st.com/mcu/modules.php? name=mcu*file=devicedocs*DEV=STR711FR2*FAM=86) there was description HDLC! And now is not present! The where description disappeared and when to appear? :o
2006-05-29 05:51 AM
HDLC on STR71x has some 'aspects' that should be discussed with ST if you plan to use it in any important applications.
There are some matters that were not addressed in the sample code that had been posted and are not covered in the Nov 2005 reference manual. Can you use another serial protocol for your application ?2006-05-29 06:13 PM
Is not allowable to use other report in my application! For me it is necessary HDLC.
Updated document HDLC will be laid out! If yes that when?2006-06-05 06:18 PM
The when documentation on HDLC will be laid out??
[ This message was edited by: Muxamor on 08-06-2006 11:39 ]2006-06-07 11:07 PM
Sirs carrying out support STR71x!
Can you will answer my question on HDLC?2006-06-08 05:26 PM
Quote:
On 08-06-2006 at 18:45, Anonymous wrote: Hello Muxamor, The HDLC document are removed from the web and will not be released. Could you please send me your e-mail and we will contact you to provide you more information. Thanks and best regards, Email:mailto:ivan@sigrand.ru
I shall wait for the letter. Thanks and best regards2006-06-12 06:29 PM
RISC!
I and have not received the documentation on HDLC! If you sent send once again! [ This message was edited by: Muxamor on 13-06-2006 08:34 ]2006-08-25 07:49 PM
Hi, RISC,
I'm now using STR71x HDLC in my project which is highly depend on HDLC behavor. Could you kindly send me some updates about this HDLC module? Such as known issues or problems will be very helpful. Thank you.
