2004-11-24 01:31 AM
2004-11-17 04:03 AM
I use the ST7-STICK to programm my ST7FLite2x. Reading the AN1754 I found that you can test the ST7-application under the ICC-protocol. Has anybody of you experiences in in-circuit-debuggig via ICC protocol and the ST7-STICK. Or do you know a good software system ready to use? Can I include the STVD7 software and how? Thanks for any idea, WoRo2004-11-24 01:31 AM
Hi Woro,
Unfortunatly the Stick does not support ICD (In Circuit Debugging). You have several hardware that supports ICD on the ST72FLite2x using STVD7 as IDE: * InDart from Softec * EMU3 from ST * DVP3 (starting from STVD7 r3.1 to be released in December 2004). As the ICC/ICD is open, you can expect other third parties to support it but not with STVD. Alain
