2006-06-20 04:39 AM
Connecting I/O pins directly to ground
2011-05-17 12:30 AM
The ARM9 datasheet recommends connecting unused I/O pins to ground (rather than through resistors?).
There could be a situation where the software engineer incorrectly configures an I/O pin (it happens 🙂 ) to output mode. Can these I/O pins not be set to output mode in software at startup. I know there is small period of time at startup when the I/O's are not configured, and could be susceptable to noise. Is there more danger of the core being upset due to noise on the STR9? Thanks, Marty.2011-05-17 12:30 AM
Hi
I suggest to use pull-down resistor and not to connect unused pins to ground directly best regards, Punto
