Connecting I/O pins directly to ground
md1
Posted on June 20, 2006 at 13:39
md1
Posted on May 17, 2011 at 09:30
The ARM9 datasheet recommends connecting unused I/O pins to ground (rather than through resistors?).
There could be a situation where the software engineer incorrectly configures an I/O pin (it happens :) ) to output mode.
Can these I/O pins not be set to output mode in software at startup. I know there is small period of time at startup when the I/O's are not configured, and could be susceptable to noise. Is there more danger of the core being upset due to noise on the STR9?
Thanks,
Marty.
halim
Hi
I suggest to use pull-down resistor and not to connect unused pins to ground directly
best regards,
Punto
