2005-12-25 07:57 PM
big size file downlod to the main flash
2011-05-17 03:09 AM
hello,everybody!
i'm using psd3254a,and want to write a file(256KB)to the main flsh by psdsolft using flashlink cable.but there is some trouble with loading the file .the file format is .lib or .bin ,the psdsolft d not recognise the file ,and came to an error! is it necessary to divide the 256KB file into 8 files?(32kb per file) or convert the .lib or .bin format to .hex format? if so what should i do? or is there another way to SOLVE THIS PROBLEM? my e mail ismailto:lu0818@tom.com
thank you very much!
