big size file downlod to the main flash
lu0818
Posted on December 26, 2005 at 04:57
1 REPLY 1
lu0818
Posted on May 17, 2011 at 12:09
hello,everybody!
i'm using psd3254a,and want to write a file(256KB)to the main flsh by psdsolft using flashlink cable.but there is some trouble with loading the file .the file format is .lib or .bin ,the psdsolft d not recognise the file ,and came to an error!
is it necessary to divide the 256KB file into 8 files?(32kb per file)
or convert the .lib or .bin format to .hex format? if so what should i do?
or is there another way to SOLVE THIS PROBLEM?
my e mail is
mailto:lu0818@tom.com
thank you very much!
