2005-07-25 11:32 PM
2005-07-25 11:07 PM
The function RCCU_FrequencyValue in the file rccu.c is wrong.
the RCCU_PLL1_Output case contains the incorrect factor: case 2: Mul = 28; break; regards whh2005-07-25 11:32 PM
Hi whh1,
Yes you are right this mistakes is already detected and 28 have to be changed to 24. it will be corrected in the next release. Thank you and best regards, Hich 😉
